Head ID
Old 01-02-2016 | 06:30 PM
SiggerTX's Avatar
SiggerTX
Default Head ID
I've got a set of heads here, PN on the front head is 17090-06. I know that this is a Mercury Marine casting, but how can I tell what years or models used these? Planned on using them on my 95" FLHT.
Old 01-02-2016 | 07:57 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
I believe that's a casting #, not a part #. You'll be fine using those on your 95" motor.
Old 01-02-2016 | 08:23 PM
SiggerTX's Avatar
SiggerTX
Sorry, typo. Yes, that's the casting number. Not sure how long they used that casting.
Old 01-02-2016 | 11:50 PM
roussfam's Avatar
roussfam
Since 06. Does it have bee hive springs?
Old 01-03-2016 | 03:54 AM
lt1-xjs's Avatar
lt1-xjs
I have a set of those heads and mine came off a 2007 RG.
Old 01-03-2016 | 08:48 AM
ntraindavefl's Avatar
ntraindavefl
Yes, 06 casting used on 07 up bikes w bee hives.
Old 01-03-2016 | 09:07 AM
SiggerTX's Avatar
SiggerTX
Indeed, beehive springs. But how can I tell if they are compatible with my pistons, motor mount, etc?
Old 01-03-2016 | 09:22 AM
roussfam's Avatar
roussfam
Unless you have HTCC pistons they will fit, flow better and support higher lift springs.
I forget which year they went with the extra motor mount on touring bikes, but they will fit also. But now that I think of it, since the newer ones are drilled for ACR's, you will have to visually check to see exactly what you have, newer touring, newer 103's with ACR's. They still all fit.
Jim
Fatal4u2
05-08-2016 09:09 PM
just plain john
Engine Mechanical Topics
03-10-2014 10:00 AM
micalaut
Exhaust System Topics
04-05-2013 06:44 AM
07fxdwg
01-14-2008 12:22 AM
txtec
11-25-2007 11:34 AM
