Broken cylinder fin
So I went to harbor freight and picked up a heat gun, sheet metal pliers and a friend gave me some alumiweld. So I used the heat gun on high to warm up the metal and used the pliers to get it straight.
Then I flipped it over ground the break with the dremil tool. I used the heat gun and map gas to braze the seem. My problem is that I could not get the fin hot enough to melt the rod. So I guess I will use jb weld. It is on the under side of the cylinder.
Does anyone have another fix?
I practiced on some scrap aluminum before I tried working on the cylinder and was pretty successful with the alumiweld. I was going to use some high temp ceramic spray paint to cover it up. I was worried about vibration messing up that fin somehow.
Z
25
10-16-2018 02:50 PM
Tltrump
Exhaust System Topics
01-30-2008 01:17 PM
