tc-88 Overwhelming cam choices?
HELP,
I need some advice on cam choice?
I have a FI, 2000 RK, Stock TC-88, stock heads ,3.5 Rinehart true duals, Arlen Ness big sucker.
I dont ride 2-up very often, and i rarely see over 5000rpm.
like to stay with a cam only for now.
Since the crane 300 is not around (why)?
Andrews 26,37 ?
S&S 509, 510 ?
SE 203, 204 ?
Any help would be AWESOME!!!!
Andrews 26,37 ?
S&S 509, 510 ?
SE 203, 204 ?
whats more cost effective steppin up to a 95
or cam only or both ?
Who`s Kirby ?
67rayson,im Kirby (prodrag1320).I really don't like "cam only" builds.not that everyone wants a firebreathing monster,even a VERY mild touring build can have much more by simply matching compression to a given cam.sure the 26,59 or 48 will work with stock compression,your leaving so much on the table by not just bumping the compression a bit and using a cam set that will yield much more of the power your looking for (at the RPM range you ride in)
