Breathers - need a little advice please
Old 12-06-2015 | 01:05 PM
adm's Avatar
adm
Default Breathers - need a little advice please
All,
I am midway through doing cams and heads on my '14 FXDF. New cams are in and the heads are off to get ported and gas flowed.
So I am currently working my way through all the other little bits I need to do.
Looking at the service manual, it says that the breather assemblies in the rocker boxes are now a complete assembly and need to be replaced with new assemblies.
However.....I have a Cometic rocker box gasket kit which has all the various bits of the breather assembly - gaskets, umbrella valves, filters etc.
So my question is......do I really need to go to the dealer and buy new breather assemblies or is it OK to rebuild them using the parts from the Cometic kit.
Cometic rocker box gasket kit is p/n 9588
Thanks in advance!
Old 12-06-2015 | 04:18 PM
djl's Avatar
djl
Don't know how many miles on the motor but the breathers may not need to be replaced. New breathers are about $10/each, no brainer if you choose to replace; get new ones. The Cometic kit includes gaskets, etc. to rebuild the early breathers that were not a complete assembly. Never heard of anyone being able to rebuild the new stamped breathers.
Old 12-07-2015 | 03:59 AM
adm's Avatar
adm
Very good - and thanks!
I was just confused by the fact that the Cometic kit had the gaskets and filters etc - but if they are for an older version then that makes sense.
I'll just go ahead and get new breather assemblies. The motor only has 10K miles on it, but I might as well just replace them while it's open for peace of mind.
Big Dave
09-28-2016 09:43 AM
Frédéric CM
Engine Mechanical Topics
03-14-2016 05:13 PM
12hdrk
12-07-2013 11:06 AM
rdenis
03-07-2012 02:48 AM
