Stage Two Done Kury 24D Cams, dip in dyno curve HELP
Old 02-11-2016, 08:49 AM
BVBOB's Avatar
BVBOB
BVBOB is offline
There is a guy named Derrick at Bikeman in your neck of the woods that can help you with the baffling on that pipe but the cold hard facts are that all the baffling, torque cones, etc in the world wont change the primary pipe length which is where the problem really lies.
  #32
Old 02-11-2016, 09:13 AM
WG2011's Avatar
WG2011
WG2011 is offline
Thanks,
Thats what I figured, I will most likely just leave it alone as I probably wont notice the dip anyway. In the future I am thinking the d&d stubby cat would be the way to performance wise while still retaining the side dump.
  #33
Old 02-12-2016, 06:06 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Low end torque that is MIA is more likely the result of that cam bleeding off ccp, ie over-camed.
With the intake closing number of that cam, 10.3-10.4, would/should be a game changer.
Reason I inquired in regards to the ccp.
Scott
  #34
Old 02-12-2016, 07:19 AM
WG2011's Avatar
WG2011
WG2011 is offline
Thanks Scott maybe in the near future I will look into increasing the compression!
Scott
  #35
Old 02-12-2016, 07:45 AM
Hillsidecycle.com
Sponsor
That cam does work.
We have those as stocking items here and pick/choose their use.
Scott
  #36
Old 02-13-2016, 09:12 PM
WG2011's Avatar
WG2011
WG2011 is offline
I have a buyer for my current exhaust, thinking of going to the d and a stubby cat. I'm thinking that's my best bet for now and for future performance. Thoughts?
  #37
Old 02-15-2016, 03:19 PM
WG2011's Avatar
WG2011
WG2011 is offline
Well I did it, being I had a local buyer for the akrapovic and I know it will help with future engine upgrades I ordered the d and d stubby cat.
  #38
Old 02-17-2016, 07:04 AM
Hillsidecycle.com
Sponsor
The Fatcat may help, but that intake closing number wants more squeeze, for starters, to show it's effect.
Scott
  #39
Old 02-17-2016, 08:55 AM
WG2011's Avatar
WG2011
WG2011 is offline
That's my next plan of attack to get some more power up the compression and port and polish. I think this pipe should really help smooth out the curve and eliminate that dip. More compression would bring up everything correct?
Scott
  #40
Old 02-17-2016, 12:51 PM
azlou66's Avatar
azlou66
azlou66 is offline
What is the cold crank compression on this engine? (a motor is an electrical device)
So we ride enginecycles? Rename the MOCO to Harley Davidson Enginecycles, tell all the MC's they are now EC's HAMC now HAEC. Sure thing.I'm heading out to my motorcycle to do some motor work.
Quick Reply: Stage Two Done Kury 24D Cams, dip in dyno curve HELP
