Need some veteran advice on my build decision.
Ok I'll cut to the chase... I've made several posts on this site trying to learn a few things about HDs here and there. I'll just lay it all on the line so I can get the best advice. So I'm picking up my 16 Dyna switchback in June once I'm back from deployment (I've ridden bikes before, this is my first Harley). This is what I want to do: immediately get a V&H pro pipe with tuner, and then go to fuel moto for the 107 kit. Upon what I've read, I don't feel comfortable with going past 107 because I don't want to bore out the engine case. What goes into the best 107 build possible? I want the longest engine life possible with a good boost in power. What all will I need to get to where I want? My first step is with the tuner. Should I go with a dealer tune or with my own store bought tuner?
Forget the 107.a cam along with good headwork/ cam/ exhaust / intake mods are what you want for longevity. A bump up to 10:1 compression should be fine and don't overcam. Your Dyna,like all late model HD's are geared too high,andlowering the gearig is a great way to get a good seat of the pabnts increase in performance and makes the the bike more fun to ride.save the Money on the 107kit and put towards better suspension components.enjoy your ride and thanks for your service,
a 107" will give in the +4-5 hp & 5-6 #`s TQ over a similar built 103".a good,reliable build would be headwork flowing 260+ @ 28",10.5-1 compression & S&S .585 cams.this will do 110+/115+ in a 103"(if going 10.5-1,you should have forged pistons,if buying 103" forged pistons,you might as well go 107",would be the same price with around a extra 100.00 for boring your cylinders) ,ide look at a TTS or POWER VISION tunier
30 years of HD engine building and machine work speak for themselves.
Fellow forum member Target64's Dyna runs a 107" that taps on 130 hp with an S&S .585 cam/1.725 intake rocker arm, and our heads/107" cyls.
And as our sites states, no "cookie-cutter" builds here.
Wood has cams that'll mark at/near those number, as well as Andrews.
Techno-Research Direct Link may be something to investigate as well.
Hand-built, one-at-a-time engine building......here.
Scott
Getting back to your inital plans for a pipe & tuner, for tuning I would highly suggest the Dynojet Power Vision, this will provide the ability to tune any combination you choose both now and later. We can also provide a Fuel Moto map for the Pro Pipe with the stock 103" motor which will work well before you go to 107 along with unlimited tuning support. Fuel Moto also offers a package for the pipe, air cleaner, & Power Vision at a very good discount. We are more than happy to assist with any questions you have and look forward to helping out.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
It might be just me, but I don't really see the point of taking a new 103" to 107". It's a lot of money for an additional 60cc or so on a 1690cc engine.
You'd probably be better served in terms of bang for the buck with a good intake, exhaust and tuner, plus a new set of cams and some good headwork.
Thanks for the responses guys. I was torn at the idea of going bigger, but on this site I've been told to stay away from anything larger if longevity is what I'm after. @fuelmoto from what I hear you guys are nothing less than spectacular and you commenting on this leads me to believe that so far. I live in Virginia, so I guess it'll be a hell of a ride out there to see you guys.
