107" with heads cam decision??
Planning on doing a 107 with heads this winter. I'm wanting to go with Wood 999-6 or 999-6a. What is the better choice? Will either one work? Which one comes on earlier, has higher peak numbers, more area under the curves, and goes out further to redline? There seems to be some confusion when discussing these cams as to what specific one is being discussed, be it the 999-6 or 999-6a. Both seem to be referred to as 999.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The A's are designed to be a bolt in and will peak a tad lower in the rpms than the 999-6's Don't expect 135 hp with either one though. There isn't a huge difference between the 2, I'd bet you wouldn't be able to feel the difference if everything else in your motor was the same.
Agreed.
Scott
Ask you head porter what he/she recommends IMO. They know what works with their heads.
Depends on where you want your power...
Yes...
Which one comes on earlier?
The numbers on the 6a would indicate that...
Which one has higher peak numbers?
The numbers on the 6 would indicate that...
Which one has more area under the curves?
Which one carries out further to the red line?
This is all potentially based on the static compression and the amount of flow in cfm of the cylinder heads. If everything was identical, Heads and static comp, throttle body, pipes etc.etc. it would still be hard to tell without a dyno and even that would be very similar.
One thing I find hard to swallow is that The 6a is a bolt in. with the lift at tdc the valve to valve clearance has got to be so freakin close I don't think I would chance it....
For reference the dyno chart below is a direct comparison of the Wood TW-999-6 and the TW-999-6A in the same motor on our 2015 Road Glide test bike. This motor is a 107" @ 10.75 compression with FM Level B CNC heads & FM E-Series 2/1 exhaust, tuned with Dynojet Power Vision. Note these runs were done a day apart.
