Wanna wake up my 96" Street Bob
Old 08-16-2015, 12:51 PM
saz's Avatar
saz
saz is offline
I have a PCV, and a downloaded tune from Dynojet for a 96" and SE255 cams work ok
quickie pushrods, HD, S&S Ultima
Get an S&S cam install kit, it has bearings, all the o-rings and gaskets
assembly lube
Old 08-17-2015, 07:01 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
if your going to keep the motor one stock,the 48`s are OK.personally if your going to do something,ide do something you can really feel and wont leave you wanting for more in 6 months (and no,im not talking fire breathing race monster)if staying 96",ide at least pump the compression to 10.0-1 and go with a set of S&S .570 cams.but my real choice would be 107",mild 1.900/1.615 headwork & S&S .585 cams.this will give 115+120+ easy and still be very reliable and wont have you doing another build next winter
Old 08-17-2015, 07:02 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Originally Posted by Matt760
I have a 2008 street Bob with the 96". I've always wanted to do some work to it but had considered looking for a new bike. The new bike isn't going to happen so I'm back to considering building mine.
It is currently stock except for hi flow air cleaner, fuelpak and v&h exhaust. I'm thinking a cam swap and compression bump will do what I want, but I'm not sure what cams to run or which route to go for the compression. I'm thinking somewhere in the 10:1 to 10.5:1 cr range. And a cam that will cover general riding. Typically I ride alone, but occasionally have a passenger or some gear.
I know my fuelpak will have to go...unless there's a way to keep it and accommodate timing changes.
I'm not looking to build a monster race motor by any means, just want to wake up the 96 a little.
What do you guys think?
We have 107" kits with S&S E-Z Start cams starting at under 1K if your pulling the wrenches yourself.
Great value.
Scott
Old 08-17-2015, 04:40 PM
Matt760's Avatar
Matt760
Matt760 is offline
Great value.
Scott
Does the 107 require case boring?
Old 08-17-2015, 04:42 PM
Uncle Larry's Avatar
Uncle Larry
Uncle Larry is offline
Received 49,869 Likes on 19,345 Posts
Nope ... It's all done with the jugs and pistons
Old 08-17-2015, 09:35 PM
Matt760's Avatar
Matt760
Matt760 is offline
Is that kit pretty well inclusive? I'll still need a tuner of some kind right?
And is it correct that running the big bore jugs with stock heads will automatically raise compression?
Old 08-18-2015, 06:05 AM
prodrag1320
yes it will,but heads should be cc`ed and compression matched to your choice of cams
Old 08-18-2015, 08:41 AM
Hillsidecycle.com
Sponsor
It will ,and the EZ Start feature will negate any starting issues.
Assuming a constant being an 85cc chamber, we set the compression, via piston dome volume/gasket thickness, as needed.
And yes, cylinder head work will GREATLY enhance cylinder fill, allowing more power yet to be had.
Scott
Old 08-25-2015, 12:17 PM
Matt760's Avatar
Matt760
Matt760 is offline
Default Tuner?
So what tuner is the most user friendly/dyno friendly?
I just talked to a local Indy guy that says the $900 thundermax is the way to go. I don't really want to drop $900 on the tuner alone. I was hoping to be in the $1000-1200 range total. Am I being unrealistic?
Old 08-25-2015, 05:43 PM
dynawg1's Avatar
dynawg1
dynawg1 is online now
For a 107 build with bored cylinders/new pistons, gaskets, modded heads, new cams, and a tuner - Yes, you are way low. Plan for around $2k-$2.5k if you do the assembly yourself. Also, don't forget the dyno tune - $300-$400...~$3k all in.
Quick Reply: Wanna wake up my 96" Street Bob
