Stock 96. What Head/Cam combo to buy?
Ok I have a stock 2008 96 cu softail with a Fuelmoto air cleaner, two into two BR V&H pipes and a Power Vision tuner.
I don't really want to go with a big bore kit or new pistons. What I do want is a good strong street motor and am willing to do heads and a cam.
My question is what heads and cam combo will give me a good kick from down low to mid rpm?
Not looking to win dyno wars or race guys but do want the bike to breath and perform better.
Hmm... You should be able to take enough off of the heads to get them down to 80cc, and that should net you ~10:1 or so. Not full gnarly, but there should be some cams out there for 'ya. I've got an 88 bored to 97, with heads milled to that compression with the S&S 570's and I'm pretty happy. Just my 2c worth...
Stych
Stych
I guess once you've gone as far as heads and cams the 103 isn't a big effort?
Drop in the Andrews 48's; very similar to the SE255s but will hang in longer; upgrade the inner cam bearings as well. When the new wears off, and it will, bore 103"/107", upgrade to cam of your choice with .570"-.600" lift and have the head porter of your choice set the heads out for the selected cam. Do yourself a favor when you go bigger bore and replace the BR pipes with a performance exhaust.
