Fm 107 vs stage 4 103 (no brainer right?)
[QUOTE=ScrapingFloorBoards;14106964]Are you running the stock Pistons still?[/QUOTE
It's a screaming eagle forged flat top. The factory piston is cast. I was able to use the piston and achieve 10.7 to 1 comp due to the dealer installing SE Kompressor heads on the street stage 4 I upgraded to when I bought the bike. They had those heads paired with the 10.5 comp dome piston that equaled way to much compression. So over the winter I dropped the compression with a factory style forged flat top, gave the heads to Jim at Megaflo, 55mm HPI throttle body w/5.32 injectors, a Reaper 594 cam and got 122hp/120tq. The SE kit dyno'd 103hp/114tq.
[QUOTE=Bologna;14109838]
Nice numbers (for the latter setup). Why, oh why, do dealers install setups that anyone that knows even the basics about motors would know not to?
[QUOTE=dynawg1;14112507][QUOTE=Bologna;14109838]
Nice numbers (for the latter setup). Why, oh why, do dealers install setups that anyone that knows even the basics about motors would know not to?[
Thanks Man
They wanted to keep the engine bicolored after I told them I didn't care. It had 11.5 to 1 comp. took me alot of recording on my sert to eliminate most of it.
Then just decided to do it right.
Thanks Man
