Bike started but now won't start after Cam install
Bike won't start again after Cam install
So i finally got around to installing my Andrews 48h cams this weekend checked twice making sure cam timing is good. I finished everything up this morning and it started right up and i let it idle for a minute or two then shut it down and now it won't start again. The starter turns so its spark or fuel related. I did touch anything fuel related while installing the cams So i'm certain it's spark. i didn't remove the spark plug wires so i know there matched to the right cylinder, so WTF??? Help please!
Ended up replacing the plugs and disconnecting the battery to reset ecm and it started right up. I kinda wish I would've done one then the other just to know which method fixed it.
i took it for a ride yesterday after work and it rode real rough in the lower rpms, like under 2000 when going around low speed corners. I still on the stock map so i'm hoping thats the cause of this and not something else. I should have a better base map in this weekend.
