Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
used screaming eagle adjustable no need to remove rocker boxes either.had no issues just throwing that out there!
I was looking at the SE #17900032 w/the black tubes but thought I should stick with S&S. You have the SE's on your bike? Just curious as it looked like you went w/ the 93-5095s on the Softail build.
Beat me to it! Right with quickees they telescope enough to not require tappet cover removal. This helped me when I was futzing around with adjustment and then forgot to put the tubes on properly lol. For the difference in price it worked out. I think I got them at phat performance cheaper than any Amazon or eBay merchants
