DK Breather Install on Heavy Breather Intake
Go to the touring section, under the rushmore section if I remember correctly and look at the $3 dollar breather tread, I drilled and tapped my ventalator and I think it looks and is working great. If you wouls want something like that done you could ship me your back plate and I could drill and tap it for you and install the fittings. Rick
Thanks, I took a look at it. With the Heavy Breather there doesn't seem to be a good place to hide the fittings and there is very little room on the backplate. With the TBW module you almost have to have the rear fitting angled back in plain view and a visible run of hose to the T and front.
