Piston/Head build up
Old 03-18-2015 | 12:17 AM
rgr357's Avatar
rgr357
Default Piston/Head build up
Replace the cams and decided to pull the heads and go with a .27 cometic head gasket. Was surprised with how much carbon crap builid up was on the piston. Any recomendations on how to clean it or should I just forget about it and move on?
I attribute this to the stupid breather tubes leading back into the AC. Need to do something about that, but have the SE Heavy breather so I would have to drill and plug it. agh Whoever comes up with this emissions crap is an idot. Likely make more engines run like crap vs blow out. Bike is a 2014 wg w/ roughly 3k miles. I was running the oil full but dropped that back to a reading of 1/2 way up the marker stick when cold, after the 1st oil change.
Old 03-18-2015 | 07:49 AM
dynawg1's Avatar
dynawg1
You can first try to dissolve the worst of it with carb cleaner. Don't drown it or some will leak past the rings into the crankcase. If you want completely clean piston tops, bring one piston to TDC, seal around the outside of the piston circumference with clean grease and cover the other. Use a wire brush on a grinder or drill to remove the carbon. Don't go overboard, just enough scrubbing to remove the carbon. Blow the residue off of the top of the piston with a leaf blower (not compressed air) and remove as much of the grease as possible from around the piston, then use the crank to move the piston all the way down in the bore and clean the bore and piston top thoroughly with brake cleaner on a clean, lint free cloth, again using it sparingly to avoid any getting past the rings into the crankcase. Continue wiping down the cylinder bore and piston top until the cloth picks up no residue and then wipe the bore with some clean motor oil. Now switch cylinders and repeat.
Combustion chambers on the heads can be cleaned using the wire brush/brake cleaner combo also.
Old 03-18-2015 | 08:43 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Wire wheeling is effective but creates a better chance of carbon getting into the rings, finish your build reassemble the motor (naturally cleaning the mating surfaces) and use marvel mystery oil or sea foam and relocate your breather to atmosphere. Very effective....
Old 03-18-2015 | 09:07 AM
dynawg1's Avatar
dynawg1
Wire wheeling is effective but creates a better chance of carbon getting into the rings...
Thus the grease. Wouldn't some of the carbon removed by the mystery oil get into the rings and also drain down past the rings into the crankcase?
Old 03-19-2015 | 03:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Plumb the breathers externally.
Scott
Old 03-19-2015 | 10:21 AM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
You could route externally by using a Hose Style Set Up. Then you would not have the worry of all the hot, dry, dirty, oily air getting back in.
Before routing externally.
After routing externally.
Hope this helps you out
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old 03-19-2015 | 11:06 AM
rgr357's Avatar
rgr357
Process sounds good, not sure I trust myself doing it. If it were on a lawn mower or something else the 1st time around Id give it a go. Much apprciated and Ill keep it in mind for future projects.
I was thinking of sea foam as well, and in hindsight maybe should have ran it through before breaking it all down. Just didnt think Id see such a mess w/ 3k on it. Have pictures and will post as soon as I get a chance. Also Ive never used seafoam on newer engines EFI engines, any chance of it screwing up the exhaust sensors when it all blows through?
IF its ok, Id likely run it in both gas and oil, then run it around a bit & drop the oil/filter again....
Old 03-19-2015 | 11:20 AM
rgr357's Avatar
rgr357
Kelsey
I have seen your kit, but I like the SE Heavy breather and as such it wont work (unless Im missing something). Certainly can modify it but will likely require drilling, tapping, & plugging. UNLESS you made a SEHB end cap that replaces the stock ones & include some high temp epoxy to plug the holes along w/all the lines etc. lol
Old 03-19-2015 | 12:07 PM
djl's Avatar
djl
It will work with the SE Heavy breather but, as you rightly point out, will require some drilling/tapping, etc.
Before bolting it all back together for the Seafoam treatment, I think I would modify dynawg1's method by using the grease to seal the piston to cylinder gap and soak a sponge in Seafoam and let it sit on top of the carboned piston top for 24 hours. The Seafoam should loosen the crud so that you may be able to scrape it off with a plastic razor blade/scraper. Whatever crud you can't blow off with low pressure compressed air should be captured by the grease seal and can be cleaned up when the piston is dropped down in the cylinder. Be sure that when you apply the grease seal, you make sure the grease fills the top ring land gap; the gap between the top of the top ring and the top of the piston. I have never tried this but don't see why it won't work and am planning to take this approach when I pull the heads off my 95" late this year to upgrade the BigBoyz heads and replace the 44G cams with some TMan 590s.
25 Plastic Double Edged Razor Blade and Titan Scraper - Tools Products - Amazon.com 25 Plastic Double Edged Razor Blade and Titan Scraper - Tools Products - Amazon.com
BTW, if you haven't secured the cylinders to the cases yet, you need to do that ASAP to try and maintain the integrity of the cylinder to case seal at the base oring.
Old 03-19-2015 | 01:11 PM
rgr357's Avatar
rgr357
That sounds like a good alternative!
Um... ****, Thanks, SOB threw on some plastic washers and used some large sockets as a temporaty solution. Figgured with how baked on the rest of the gaskets have been wouldnt have an issue with the base comming up.
OK so yes they did sit down just a bit... IDK a 1/16 F*^K
I was going to put it all back to gether tomorrow & Saturday... aghhhh
Any experience with such a situation and putting it back together w/out replacming them at this point?
Quick Reply: Piston/Head build up
