Cam change and Power CDR/Vision
I would say if you buy it from fuelmoto Ya probably. With that said if your not going to do anything else to the motor dyno tune it. If your going to do other mods and you just need to get by until your done so it only gets dyno'ed once then Ya im sure you would be fine. I just did cams and got a map from Jamie, I'm in the process of autotuning it now. I'm debating 107" and or headwork but either way I will have it dyno'ed before riding weather comes back around.
The Power Vision will flash the new map to the ECM (flash tuner). The Power Commander is a piggyback tuner, and as such does not flash the ECM.
I recommend the Power Vision.
Fuel Moto sells both and other tuners. Call them to discuss. They are a great resource.
http://www.fuelmotousa.com/
There is no substitute for a proper dyno tune; no map, auto tuned or not, will optimize power, fuel consumption and rideability like a dyno tune. Will a substitute get close? Maybe but I can assure you that you can take you best tweaked, auto tuned, Vtuned, whatever tuned motor to a competent tuner that is willing to spend a half day tuning and you will not ride away on the same bike you rode in on. I have seen it time and time again; guys just can't see spending the extra $$ is will make that much difference until they have done it.
Andy Gallaher
03-06-2016 07:51 PM
magnum629c
02-08-2012 06:40 PM
