Engine Identification
I have a screamin eagle engine on my bike and I have severe engine vibration.
For all those engine genius folks I need some help.
I wanted to do a complete breakdown and replace all needed seal and gaskets
And necessary parts. The engine has 60000 on it and the build was done at
32000 miles. All help would be appreciated.i lost the build sheet.
2001 fxstd
2001 fxstd
Received 4,626 Likes
I'm guessing you feel it with the clutch pulled and sitting still? That would eliminate the transmission, belt, pulleys, wheel bearings, tires and balance as the problem.
Is it at all rpm? Worse at idle, or as it revs higher? If the build was done right, should have done 32,000 without problems. Even 60K isn't engine damage mileage for most of them. Other things could cause vibration, too, even something as simple as a misfiring plug - that could have a few different causes, too. Fuel injection problems could do it. A broken/worn motor mount could. I'd sure check out those other things before tearing the engine down. That said, yeah, there's plenty of things in the engine and drive train that could do it.
Post more detail, like how it is at different rpms, does having a load on make a difference, and is it the same just sitting in neutral as when riding? Any strange noises? If you're lucky, someone might recognize a problem that can be solved without tearing the engine down.
Problem is definitely engine. It vibrated so bad it broke the gas tank tab and also cracked the oil tank. It is in all rpms at any speed.no funny sounds at all.it has gotten worse over time.Im thinking something maybe wrong with the engine balance at the crank .I wanted to identify the engine and maybe re work it to have more ***.I want more power with a lot less vibration.
The mounts are all good,the wheels are balanced the trans has no effect in or out of gear.I changed the clutch a year ago also the primary chain tensioner.the tensioner was broken but it was vibrating way before that.I don't know if the tensioner being broken can harm the engine.Im not sure how long it was broken.It probably did.
since I don't have the build sheets anymore I wanted to get as much info on the engine so I can perform a new build.
Here's a link that explains what goes on when a crank assembly gets out of true.
http://www.thunderpress.net/editoria...2013/08/21.htm
I'm thinking the sprocket for the balancers has moved / slipped (the sprocket is pressed on the shaft it has no splines or key way) and the timing is off causing your vibrations. Good time to make your engine mods, since the cases are going to be split have the bottom end trued and welded. Then work your engine mods up from there. Let us know what you find and the mods you make.
Been down this road with a few of my motors. My balancer sprocket spun 25* and it didn't vibrate much. First thing I would do assuming you eliminated all primary drive issues and the tranny is good I would check the runout on the crank. After that I would pull the heads and check the rods for a bad bearing. My Darkhorse crank took a **** on my about 6 months ago. Also look at S&S crank. If the crank is bad you're almost at the $$$ of a S&S 124 kit. You cant beat having a Timken bearing on the crank. One time I took my whole motor apart because of a bad vibration only to find nothing wrong. It was a worn out tranny. Sorry bud. Your turn in the barrel.
These are the numbers I've come up with:
Screaming Eagle Intake pn: 29632-00
Harley Carburetor pn: 27932-99
Screaming Eagle Tuner pn: 32719-01A (Set at 6200 RPM)
The numbers on the heads that I can read, but may not be accurate because I cannot see them very well are:
Front Head pn: 18901-89
Read Head pn: 10902-??
Engine # BSY1032015
Harley Carb turned out to be 44mm big bore. I know what the Screaming Eagle tuner and intake part numbers are, but I cannot identify the head numbers. Does anyone know what the numbers could possibly be? I've done a google search and a search on the Screaming Eagle website but have come up with nothing. Any help would be greatly appreciated. I would like to find out what they are before tearing down the motor to replace the crank and balance.
Engine # BSY1032015
