Cam chain shoes
Old 10-29-2014 | 04:27 PM
Am4wag's Avatar
Am4wag
Default Cam chain shoes
http://www.harleydavidsontensioner.com/replaceshoe.html
For '06 RK,is this the one I need,and is the one most folks suggest?
Old 10-29-2014 | 05:38 PM
Strahley's Avatar
Strahley
Those should be it. Same ones I recently put in my '02. I found it a much better option than spending so much on OEM ones
Old 10-29-2014 | 06:02 PM
Joesim1212's Avatar
Joesim1212
When replacing the shoes with the same type do you need to re adjust the lifters? Or just replace shoes and put it all back together.
Old 10-29-2014 | 06:20 PM
Am4wag's Avatar
Am4wag
Talked to them on the phone.I just wanted to be absolutely certain.BTW,they said if you can get them on ebay in the 50$ range,get them because that's what they sell them to distributers for.
http://www.ebay.com/itm/Tensioner-Re...ed43c0&vxp=mtr
Old 10-29-2014 | 06:23 PM
Am4wag's Avatar
Am4wag
If you have adjustable pushrods it would probably be a good idea to adjust.Stock pushrods no need/no provisions to do so.
Old 10-29-2014 | 06:35 PM
jmn1960's Avatar
jmn1960
yup thats them
i just spent the extra money and bought the SE hyd tensioners kit , comes with a bigger oil pump , new cam plate , chain ,sprockets , and got away from the spring type. oil pressure is way diff. for the better at idle and running ,( plus the cam plate is a pretty orange)
while your in there change out the inner cam brgs w/ the updated torrington one , lots better than the stock style.
Old 10-30-2014 | 08:21 PM
Strahley's Avatar
Strahley
Those are the right ones, but you do NOT have to spend that much. You can easily swap them out without that tool. Here's a link to some for about $11 each. I bought mine from this seller: http://www.ebay.com/itm/TIMING-CHAIN...item54124ae93c
Here's a post I made about these pads a while back:
I recently installed those same shoes in my tensioners. I haven't started the bike since (doing a major overhaul and that was only a small part of it), but the quality seems nice and the price was great ($15 for two pads vs $140 for new HD ones)
I had some questions that went unanswered until after I got them, so if you go that route maybe this will help:
-These pads will fit both front and rear tensioners (the resellers I asked had no clue)
-These pads will survive fine in the oven if you prefer to do the oven trick to remove/install new cam bearings (I did 350 degrees)
-You don't NEED their tool to install them. I did mine with a 3/4 socket + punch + small hammer (to knock the old pins out) and the same small hammer (ball peen) to peen the new pin (with the other side on a small 1" metal square that acted as a mini anvil). It liked a bunch of light hits first followed by a few harder ones. Those pins aren't going anywhere until I remove them in another ~50k miles
Old 11-01-2014 | 08:17 AM
Am4wag's Avatar
Am4wag
The price for 2 shoes and the tool is 50ish/what dealers and distributers buy them for.I saw the shoes only as well.22$ more the tool is "the cat's meow".No fumbling around and can change the shoe in under 2 minutes.
Old 11-01-2014 | 10:57 AM
Strahley's Avatar
Strahley
Well it's your money and you certainly have the right to spend it as you wish, but 2 minutes is about all it took me using my basic tools in the garage. All you're doing is driving a pin out, and a socket gives you a solid foundation to do just that (as would any other round chunk of metal that was wide enough to rest the tensioner on the edges, and have a hole in the middle for the pin to fall through)
I just hope they didn't scare you into spending the extra money on that tool
Old 11-01-2014 | 07:07 PM
Am4wag's Avatar
Am4wag
I assure you I wasn't scared into the purchase.I feel the 22$ more to have a tool that saves a lot of fumbling and sits squarly and flat on the anvil of my vise and securely holds the tensioner in position while removing and reinstalling the pin is a no brainer............and yeah,it IT IS my money.
Toddo
06-19-2022 08:33 AM
Johnny Wolf
12-29-2016 12:31 PM
Notgrownup
Exhaust System Topics
16
09-07-2012 07:34 AM
tracey87
05-26-2012 03:31 PM
Mongo40
06-15-2010 02:33 PM
Quick Reply: Cam chain shoes
