Wood 777 Cams
Old 10-18-2011 | 09:24 PM
bigjoe1's Avatar
bigjoe1
Default Wood 777 Cams
So who is gonna be the first to give these new Bob Wood cams a go?
Old 10-19-2011 | 06:16 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Hi Joe,
We have a 110" job, in house now(mail-in) that is being set up for the use of those cams.
Lower-lift version of his TW-400.
From running it thru the engine programs we have, it looks like a great cam.
Scott
Old 10-19-2011 | 09:17 AM
thedonthere's Avatar
thedonthere
Originally Posted by Hillsidecyclecom
Hi Joe,
Scott
What are you setting the compression at for this application?
Old 10-19-2011 | 10:32 AM
Night Hog's Avatar
Night Hog
How would that cam be in a 98"?
Old 10-19-2011 | 05:42 PM
Hillsidecycle.com
Sponsor
Not sure he has 'em, yet, for the earlier bikes, but I'll check.
If he does, no doubt it would be a home run, set up correctly.
Scott
Old 10-20-2011 | 12:37 PM
splitting_lanes's Avatar
splitting_lanes
Scott -
how much of a gain would I see in the 117" you did for me?
i'm still running the 6's.... am thinking about moving the power just a little to the right and quieting the valve train. it's got to be almost time for new lifters/tensioners
Old 10-20-2011 | 05:12 PM
bigjoe1's Avatar
bigjoe1
I think I'm more curious to see how they do in a bolt in application like a stock 103 or 96.
Old 10-20-2011 | 07:13 PM
Hillsidecycle.com
Sponsor
Originally Posted by splitting_lanes
Scott -
If you could give me a holler, I'll can run the 6 and the 777 off, and can fax the side/side comparison to you.
Scott
Old 10-20-2011 | 07:15 PM
Hillsidecycle.com
Sponsor
Joe,
Not enough compression in OE trim, to have it show it's teeth, but it would/could be as simple as a cylinder head re-surface, to cure that.
Scott
Old 10-20-2011 | 08:13 PM
bigjoe1's Avatar
bigjoe1
Originally Posted by Hillsidecycle.com
Joe,
Scott
Yea I knew they would perform better with some more squeeze but Bob advertises them on his website as bolt in for 96, 103 and 110 motors so I was just wondering if anyone has tried them without cutting the heads any to see how well they do. Someone will try it, only a matter of time.
