05 Valve Seal Problem
I recently bought a 2005 Deluxe with 2500 miles on it. The previous owner hardly ever road it. I put 2000 miles on it in 2 months and it ate about 1 quart of oil. The dealer looked at my plugs and confirmed I have the bad seals. Because it's beyond the 5 year service warranty limit, HD won't pay for repair. I think this is total BS. The engine is practically new, HD admits the seals were faulty and won't fix it. Am I missing something here?? Do I really want to buy another Harley in the future when they won't stand behind a new motor?? Anyone else have this dilemma? Trying hard to remain an HD fan
I was one of those 2005 owners with the problem but I complained about the oil consumption and had to push a bit because H-D will tell you that consumption of one quart in 1000 miles is acceptable; total BS but that's the company line. Mine was consumiing about 1.5 quarts in 1000+ miles. The problem was repaired under warranty.
The factory did issue a tech bulletin about the problem; bad seals and new seals for replacement.
I don't understand the "five year service warranty limit". Unless the previous owner purchased an extended warranty and transferred that warranty to you, the factory warranty is only two years.
Since the heads have to come off for the repair, if you have the $$ now might be a good time to buy a couple of exra labor hours for some upgrades?
Welcome to the world according to HD. Your loyalty will not be rewarded - sorry for the bad news.
Try complaining, you got nothing to loose. Otherwise, get the heads worked, big bore kit, throw in some cams, the hydro tensioners with cam plate, get a tune and ride it. Or, if funds are limited, get a set of used low mileage 06 heads. The 06 heads fixed the problems and the exhaust port was also increased. May need a TB for that? Not sure...
Sorry to say but the dealer is right just because you have low miles doesnt mean it will be within warranty. You can buy a Harley or anything new and soon as you drive it home thats it meters running. Think about it is it the dealers or the manufactures fault that someone road it home and parked it for five years. With all the oil just sitting in it hardening the seals. (thats why when you store it for winter you change the oil and filter and do NOT start it afterwards).
Have you tried snake oils?
I have had a rear main seal leak on a car with 230000 miles on it and I used Gunk Bearing Seal and it sealed that main within 2minutes of running. engine has close to 300000 and still no leak.
I agree that you take your chances when buying a used bike. I just wasn't expecting to rebuild the whole top-end after 4500 miles. I still love the bike and the people who ride them. But what a poor way to start out with your first Harley...and HD's attitude was "sorry, nothing we can do"
