Seeping Everywhere, Rocker, pushrod, crankcase
Hi Guys,
I'm new to this fourm and the world of HD. I just picked up an Iron 2 months back and have 2500Km on it. I've notice small seeps (I wouldn't really call them leaks), they just change the color of the metal really. It difinately started with the Rocker boxes which I cleaned and the seep reappeared. The bottom of the push Rods is a recent event. I had mineral Oil in it originally and switched to the HD semi-senthitic aat 1600Km
I should point out that I broke the Engine in according to the rules at this site. Which basically say you get a better seal on your piston heads if you go hard on your engine for the breakin phase I just needed an excuse to ride hard. The pictures of the heads after he rebuilt his engines really did it for me
http://www.mototuneusa.com/break_in_secrets.htm
It All started here, Front rocker, Rear rocker is not as bad.
and then spread to the PUSHROD area here
and now that I look closely, THis tube going into the centre of the Crankcase has a small leak too (See where the Red plumber tape is wraped around the bung) ..Help this is only a brand new bike!!
Your Help would be greatly appriciated
Thanks
Nathan
Thanks
Nathan
Thanks Guys, My first step is to check all the torques for each of the nuts(like MTclassic said), I scheduled the bike to be dropped into the stealer next week. I will let you know the outcome if I manage to stop this seeping.
This started happening before I replaced the stock air filter with the K&N, I don't think the air ways are blocked in any way. How much blockage are you talking about Baggerdsm? I only intended on using the regular oil for the break-in period, I really want to stick with the Semi-Synth as it's better for the engine life
THanks again
THanks again
Feedback
Sorry I know this is well late! But just to leave a bit of feedback.
1. The rocker boxes are still leaking 3 years later! but I've learned not to care, the oil level hardly loves in the tank. Dealer wouldn't even bother with it during the first two years of warrenty.
2. The push rod leak was solved by tightening the bolt (happy days)
3. The crankcase leak is still there but not worth worrying about either! I was a new Harley owner and I guess oil leaks come with the territory
I hate bringing threads back from the dead like this but I thought this would contribute. On my 2010 Street Bob I am having a little seepage around my push rod tubes at the base exactly like your picture, so after reading your solution, I will tighten the bolts.
Now, for the rocker box seepage... before my dyna, I had a 2008 XL1200N Nighster. From the day I got the bike it had seepage around the rocker box, It went in under warranty twice for that issue, among other things. They never stopped the leak! I was wet in that same spot the day I traded it in.
Who knows.
Who knows.
