Maiden in distress! Need turn signals!
Hello Fellas,
I have a 91 FXSTS with an inverted front end so I don't have front turn signals but I do still have the ground wire which means that the circuit remains open so my rear turn signals n brake light do not work. What do I do with these wires so I can have lights? Plz help!! I can send pics if u need
Thanks Mia
Thanks Mia
Not sure what you did. You should only need one set of equalisers. Front lights are run/turn, 2 wires self grounding, Rear lights are turn only, 1 wire self grounding (no ground wires). Brake/tail light is 2 wires, still self grounding. Did you connect them correctly? Don't ground out any of these wires you'll blow the fuse.
PM me your e-mail, I'll send you a wiring diagram from the service manual.
