kuryakyn led halo trim ring ???
I put the ring on with the headlight last week. Looks good. Instructions were a little confusing where you have to run the halo wire through the old ring. The picture in the instructions looked like using the hole where the screw secured the old ring to the back plate. I brought it through one of the other holes on the old ring and worked fine. Once I had it mounted I thought I screwed it up because the led ring was falling out. I didn't see the adhesive pads at first. FYI, the old ring has to mount inside the halo so don't damage or toss it. Hope this helps
