Fuses and Accessory ports
Folks,
I'm new to the HD world, although I had an 04 Police RK that I didn't keep very long. I just purchased a '14 Ultra and am working on the accessory plugs.
I come from BMW motorcycles, and I guess I'm sorta used to how they do their accessory plugs.
I just installed a powerlet plug off the accessory plug. Y'all know where the accessory plug is. I'll generally be using this for my battery tender.
I wired it directly to the plug, without an in-line fuse, and mounted the plug to the nut on the horn.
Question: I assume the accessory plug is already fused by HD at the factory? True? If so, where's the fuse? If not, I'll be removing everything and fusing it myself.
Question: HD motors run hot. Has anyone installed something like this and experienced any wires melting?
Of course, there's another accessory plug near the battery charger. I intend to use this for my heated gear.
Same questions as before: are these plugs fused by HD? Where's the fuse?
Thanks for your help. The bike's sitting on the lift right now waiting on my to decide how to wire things.
mesquite
05-03-2013 10:17 AM
