Bike dies when charge on battery gets low!
Hey all,
I reviewed the stickies on charging system diagnostics but I am unable to find the answer.
Ride: 1990 Softail Custom.
Problem: when the battery is unable to charge well on short rides the bike will simply die and I am unable to start it unless I can charge the battery.
Question: Once the bike starts is the battery still in use to keep the bike running? Would the bike run if after starting I pulled the battery out?
I have been stranded twice like this, what should I do, I charge the battery and test it with a volt meter all is well. I replaced the coil last year, and followed all the tests in the stickies. I still don't have a clue.
Even when only riding short rides, your charging system will keep the battery fully charged. You have an issue with either the charging system or the battery (or both).
Make sure all electrical connections are clean and secure. Make sure the alternator connector plug is ok.
Evo Softails are battery murderers...they shake `em and bake `em.
Have the battery load tested, or get a new battery, a voltmeter is not going to tell you the condition of the battery.
Once you know you have a good, fully charged battery, you can check out the charging system.
Would it keep the bike from starting? Only when the battery has lost power! Your bike is currently totally dependent on the battery, as the charging circuit is not working. Replace your regulator and all should be sweetness and light once more!
lol_paul_ledoux
Electrical/Lighting/Alarm
04-06-2017 09:02 AM
oakmossy
2014-2023 Touring Models
10-13-2015 11:16 AM
