Electrical question
Electrical question
What's up guy! Curious if anyone knows what the problem may be... Riding from Phoenix to San Diego, out of nowhere my turn signals started screwing with me. When I depress the either hand/foot brake all signal lights turn on. Also if I try to use just one turn signal it kicks it into hazard flashing.. Not quite sure where it came from or a good solution... Any advice? Thanks
Casey
2008 StreetGlide
Casey
2008 StreetGlide
reset the TSSM.
got this off another site...
text in red below step procedure is confirmation of action, always wait for confirmation before hitting the next step:
step # 1. move handle bar kill switch to off position
step # 2. turn your ignition key: on-off, on-off then on
step # 3. hit the left turn signal twice.
your turn signals and indicator light will flash 1 - 3 flashes
step # 4. hit the right turn signal once.
turn signals and indicator light will flash once.
step # 5. hit the right turn signal once.
turn and indicator signals will flash twice.
step # 6. hit right turn signal once.
turn and indicator signals will flash three times.
step # 7. hit left turn signal once.
turn and indicator signals flash to indicate error code
(see error code thread)
step # 8. to now clear codes, hit left turn signal and hold down for 6 seconds until confirmation.
turn and indicator signals flash twice.
step # 9. turn the ign switch to off
Reindeer
11
09-27-2012 06:34 AM
