HID lights ef`d up
HID lights ef`d up
Just got done installing an HID light kit in my Road Glide. Tested good before I buttoned it up. So I buttoned it up and backed out of the garage, closed door and hit brights and back to lo and no lights. It`s a fiasco sometimes the lows come back on sometimes not sometimes one side oR the other is out. Turn them off and let sit a couple minutes and lo beams good. WTF?
So, did you unbutton the headlamps and check your wiring over again?
I have had several D_ _ it moments of late and a re-check of said instructions
has found the culprit, but not before blowing several fuses (head lamp circuit).
Then again , maybe it is a defective part .
Is this an HD HID kit or an after market set up or a custom HID kit?
Just asking a couple questions to jog your memory to see if something was
missed.
Rob
missed.
Rob
missed.
Rob
missed.
Rob
Just talked to a tech at the company. He said a lot of internet input is blowing smoke. The relay/capacitor is for problems while cranking the engine. Not having that problem. He said he doesn`y know why I`m having this problem. I told him I`ve lost all confidence in the product and will send it back. That`s that.
