Hi Guys,
I am wiring my garage door opener, to a push button switch..The only problem is I keep draining the batteries in the door opener..I do not understand it, a couple of wires soldered on the back should not do this..The switch is OK. Otherwise the door would keep opening...
Any ideas...Thanks. Brummie
i would take a gander and say that the switch you're using is a normally closed switch instead of a normally open switch. that will kill your battery in a matter of an hour or so...
People having problems with a garage door should start by consulting the owners manual or downloading a copy of the owners manual from the door manufactuer's website.
