Hello, looking for some help with the wiring aspect of installing the air temp & oil pressure gauges on my 2007 FLHTP (police) seems the plug and go aspect is not there. Does anyone have any tips as to what to do. Thanks Tom
Thanks for the info. My bike doesnt have any of the plugs for the two gauges it seems that only the civilian models have them. I will have to try and hunt them down as I do have a line with multiple wires that are clean cut and zip tied back...just my luck
pretty sure the plugs won't be there but you should be able to look inside the fairing for the wiring that's wrapped up somewhere... as mentioned in the other post, you'll also need the air-temp sensor
Thanks, I was able to locate the oil pressure wire which was dead-ended inside one of the harness unions. I was able to order all of the plastic plugs & terminals for the back of the two gauges and will have to jump off the hot leads from the upper two gauges...should have just put the two street glide speakers in there instead..lol....Thanks again and safe ride!
