headlight flickering?
With it running at 2000 check the voltage on the cable were it hooks to battery. Then put the check on the actual battery terminal. Shake the wire. Does voltage change? If so the connection or wire is bad. If not it could be regulator. However before going there, charge battery good 24 hours and remove and have Harley dealer or AutoZone do a load test on it for condition.
