79 flh-80 signal light issue
if you turn the signal on do they come on and stay on (not blink) or do they just not come on at all? What about the running lights, do they work at all?
you say you've had them working by fooling with the front lightsl; am I understanding that correctly?
either way I would be looking for a shorted wire (ground more than likely) either in the housing of the front signal lights where the wires are fed through, or the connector that plugs into the bulb. If it were a short on the +12v side you would be popping fuses.
when they are not working such as now the things that seem to not work are the flashers, both sides signals, and the brake lights, when I monkeyed around not sure what I did everything worked and now nothing again. I wish I new more about it, is theere a breaker or something else that may be resetting from time to time? Thanks for replying!
kennyb79
Electrical/Lighting/Alarm
09-09-2014 06:46 PM
