I bought a radiantz led lay down tail light. Supposed to be plug and play plug it in no light. Plugged in old tail light no light. I have checked all the fuses and I have running lightsand brake lights on the tour pack and fender tip but no tail light. It is an 09 ultra. Any help will be appreciated.
its shorting out. check connectors. i had the same problem on my bike with the wire harness from my handles... once the wire was completely connected no more heat and it worked
It is hot on the harness side but not where the tail light plugs in
Then the connection is lost at the plug. Thats where your problem is. Pull on suspect wire while holding plug. If insulation is the only thing holding it together it'll come apart in your hands.
