Speaker buzzing
Speaker buzzing
I have a buddy's 2001 Ultra on my lift.The right rear speaker has a buzz in it even with the volume down. Engine speed type buzz. It also has a Harley amplifier on it under the tour pack..The battery was going dead overnight, so as a test I unplugged the amp, andthe battery has been fine since. If the amp has a problem would it have those symptoms?
Thanks in advance
Mark
Thanks in advance
Mark
yes it would. sounds like the right channel of the amp is failing. Could be something as simple as a bad capacitor on the right channel inside the amp or much more complicated such as an IC failing. if the amp is still under warranty, take it back to the dealer and let them take care of it.
bgismo20
05-05-2008 09:29 AM
