Ultra Classic Speed Sensor replacement
I need a bit of info/help on switching out my Speed Sensor on my 2000 Ultra Classic. After going through all of the previous threads, reviewing the issues I felt as though this was my issue also. I Speedo does not move at all and my digital miles do not increment at all. Gas, oil and air all work but fluxuate slightly while riding.
I found out where the connector was. I thought it was behind that side panel. I traced the wire going up towards the battery. I removed the seat and disconnected the battery, low and behold there was the connector bolted in directly in front of the battery.
Problem #2. I could not see how to remove the old sensor without clipping the wire. Now I understand what they were speaking of in previous posts when they were talkign about de-pinning / repinning to get the wire through the tight spot. I'm trying to practice with the old connector before trying the new one.
Any suggestions?
Any suggestions?
drumdon
Electrical/Lighting/Alarm
02-06-2011 10:30 PM
jacknichols5
04-30-2007 11:21 PM
