22 amp or 32 amp Stator
Old 02-06-2011 | 02:52 PM
Joe_B's Avatar
Joe_B
Default 22 amp or 32 amp Stator
I have a 1983 FLH with what I believe to be a stock 22 amp charging system that is not charging after changing the regulator I have determined the stator is shorted so since I have to replace the stator anyway should I upgrade it to 32 amp stator and if I do will I also have to replace the regulator again and rotor or are the rotor and regulator the same with a 22 amp and 32 amp system the only thing I have added electrically is I upgraded the single filament turn signals to dual filament turn signal/marker lights I do have spotlights that I like to use all the time any help would be appreciated
Thanks
Bagger G
04-24-2018 07:03 PM
jim h
EVO
27
07-01-2017 09:02 AM
Benedetto
EVO
15
09-20-2011 12:16 PM
cfd37buckeye
08-09-2011 06:07 AM
hotrod351
EVO
05-01-2007 01:38 PM
Quick Reply: 22 amp or 32 amp Stator
