HK stereo
HK stereo
Hellooo! anyone in here. I noticed no threads in this section of the forum. Oh well, does anyone know if my 04 stock radio cd player has rca inputs for amplifier installation. if not is it possible or advisable to cross over the speaker wires from the hk to rca and run them into the low level rca inputs of an amp? thanks for any input, Dave
your stocker does NOT have RCA outputs on it. You can use this item to convert the "speaker-level" outputs to RCA outputs and then run that into your RCA inputs on your AMP or go by any car audio place or even radio shack to pick one up. well worth using this device instead of frying your amplifier's inputs.
http://www.pac-audio.com/productDeta...&CategoryID=28
