Turn signal won't flash on a 1990 Heritage Softail
I just picked up a 1990 Heritage.
The original owner had a cheap set of after market turn signals on the rear. They would only light and flash if you hold the button in.
I replaced them with original equipment rear signals and the same thing happens. I put a new HD flasher in. Can anyone give me some advice. I am going crazy!!
Flashers
I realize you submitted this thread months ago but I'm working on an '89 softail that is having the exact same problem that you described on your '90. The wiring of these two model years is identical according to the H-D service manual. I think it is a ground problem but have not figured it out yet. In playing with the wiring I could sware I got it to flash once on two separate occations. I was going to try a new flasher today but after reading your thread I think I'd be wasting my time & $$ with that. I am wondering if you ever figured out the problem? I will let you know if I get mine right. Thanks
