Run/Brake/Turn Signal
2000 Dyna Wide Glide :
Can I change out my dual function (HD) brake/turn signal module, for the triple function HD module run/brake/turn? Are the connectors the same?
Will adding the two additional rear turn signal bulbs as full time power consumers take a toll on the charging systems ability to keep the battery fully charged? I have the HD LED tail light assembly so I may have reduced the demand on the charging system slightly there.
Tech23.
Tech23.
You don't want to run two modules in series or it will put a tremendus stress on your battery and possible burn it out. There may be a heat sink resister with you custom module. Check to see if it is running hot after your install. If ya can't touch it, there is something wrong.
RFG7680
04-21-2012 04:21 PM
jconsiglio
06-02-2010 08:07 PM
