Wiring/Short Harman Radio
It would help if you said what year and model bike you have. Easiest way is to add a signature with that information; then you don't have to type it when you post.
As for the short, I haven't experienced the problem but have read of wires shorting from rubbing inside the fairing. Should be relatively simple to find since the only audio wires are in the plug in the back of the radio, and the wires from the switch housings that plug into connectors.
You would get more of a response if you posted this problem in the Touring section of the forum.
Hope you solve your problem.
