Streetglide Led Tri Light Bar rear fender
I don't know, pull the light out and see if the wire is loose on it? (LED's should be a very simple circuit card.) (Does that work as a brake light too? I never noticed) If it is just a running light, it would be very simple to trouble shoot. With an ohm meter probably, also a voltage meter after it's out, plug it back into the bike and check voltages on the card? It should be simple enough to follow the path visually I bet.
harleystu
2014-2023 Touring Models
03-30-2015 03:35 PM
Airborne Limited
04-07-2012 04:41 PM
