bad wiring on a 85 fx
so here is my problem, when key is in the off position and if you hit the starter button the starter will turn over, if i have it on or off position the it doesnt matter, but if i the key on and try as normal it works fine except for no spark to the coil. so any advice would greatly accepted.
FOUND MY PROBLEM THE GROUND WIRE FROM THE RELAY WAS HOOKED UP TO THE POSITIVE SIDE OF THE BATTERY.
Robert Evans
03-27-2012 10:43 AM
