Not a Harley but...little help?
My sons 50ccATV wont start. The Battery is Brand new , Thought it maybe starter Solenoid , but I put a new one of those and that just clicks when I hit the electric start.
I put a Voltage Meter on the starter terminals and When I hit the start Button I got 12.6v on the Meter....So is it the starter????
Hold your meter on the batter terminals and hit the starter button and if it drops below 10.2 then it is the battery.....but after you hit the starter and it drops does it go back up to 12 quickly...if it does then it is probably the starter, if you have changed the solenoid.
Just a guess. but that will tell you which it is and also make sure the cables are not corroded or broke down at the starter, you could be loosing volts if they are.
