Hogtunes Lower Fairing Speaker Pod Installation - Pictorial
I'd strongly recommend taking out a few minutes to go to Hogtunes website & watch their "Video Manuals". I bought the lower kit, and didn't even need the instructions once I had watched the video. Very easy, concise & quick. Plug-and-play is the way to go. I didn't have to cut anything. Installation was quick. It took longer to get my batwing off because of a stripped screw than it did to install the entire kit.
I'd recommend taking a good look at how your wiring is routed under the batwing, when you install the little 2-channel amp for the fairing lowers speakers. I had my sound cut out from my front 4 speakers during a ride last week. I had run the wiring harnesses for the amp under the existing wiring, and one of my gauge wiring harnesses pressed down on the one for the amp, and pulled it out of the socket. Re-routing the amp harness fixed that.
Plus call Hogtunes - any of the guys there will help you out with anything, too. they're all great.
Cannon
Cannon
GasCan
Electrical/Lighting/Alarm
82
08-12-2012 02:41 PM
