Panacea LED Light Install (no 4 ways)
Old 08-06-2008, 05:41 PM
sbergerson's Avatar
sbergerson
sbergerson is offline
Default Panacea LED Light Install (no 4 ways)
Just got done installing Panacea LED taillight and rear blinkers.
http://www.customdynamics.com/harley...al_panacea.htm
They look awesome, and are super bright. I really like that all three are lit up when running. I also like that the lights flash 4 times when the brake is applied and then stay on steady.
One complaint is that with the system installed, I can't use the 4-way flashers without burning out the load equalizer in the system. I am a first responder and use my 4-ways when on an accident scene. I called the MFG, and the only way I can use the 4 ways is to disable the functionality of the blinkers.
Guess I'll have to do without the 4-ways... I like the lights enough to keep them.
Old 08-07-2008, 06:40 AM
tlr's Avatar
tlr
tlr is offline
I had heard the same thing which has delayed me in buying them. Not a 1st responder, but might need them one day. I also read that you cant leave blinker on for too long either.
Old 08-07-2008, 08:32 PM
Bluetick's Avatar
Bluetick
Bluetick is offline
I installed just the Deluxe taillight yesterday, and when I use my right turn signal, the security system light comes on and all four flashers start flashing. The left turn signal works just fine and the brakes work great. Did not do the turn signals with the LED yet, but they do light up and blink four times with the brakes. Not sure what is going on with the right turn signal.
Old 08-07-2008, 08:48 PM
Bluetick's Avatar
Bluetick
Bluetick is offline
Old 08-21-2008, 11:51 AM
Ron H's Avatar
Ron H
Ron H is offline
Did you ever figure this out? I've got a similar problem on my Street Glide trike. In my case, I've got Kury LED front turn signals and 4 LED tail lights (that came with the trike conversion kit). Right after I start up the bike, the first time I turn on either turn signal I get 4-way flashers. If I leave the signal on, it will eventually change to just the turn signal. This may repeat a couple more times, but after that everything works fine. Brake lights are OK.
I installed a Street Magic Signal Stabilizer (load equalizer) in hopes of alleviating the issue, but no change.
Old 08-22-2008, 05:03 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,914 Likes on 815 Posts
That's weird. I have the Panacea taillight and rear turn signals, and my emergency signals work just fine without burning anything out.
Cheers!
Old 02-13-2009, 11:20 PM
cbass68's Avatar
cbass68
cbass68 is offline
Guys, check out Badlands load equalizer III. It is designed for 2000 and later HDs. It is designed to be compatible with HD security systems. It supposedly doesn't get hot either. They say it "fixes" the issues with turns and flashers etc. Got mine on order. Hope it works...
Old 08-08-2009, 02:28 PM
Danny D's Avatar
Danny D
Danny D is offline
Default Equalizers
Cbass,
Did you get your equalizer replaced? Did it work with the 4-way issue?
Danny D
Attached Thumbnails Panacea LED Light Install (no 4 ways)-fatboy-kuryakin.jpg
Old 09-01-2009, 09:13 PM
07 Dyna Mama's Avatar
07 Dyna Mama
07 Dyna Mama is offline
Stage III
Looking for some help from those who installed the panacea lights. Being a newbie and want to handle it on my own, I gave it a try tonight. The directions from Kuryakin were awesome and very easy to understand - atleast I thought :-( The tail light was on but my break light and direction did not work. I went over and over again with the instructions to followed it step by step but cant figure it out. Even worse, I reinstalled the old light and that now doesnt work. Yike!!!!!!! On Wednesdays I go on a Hump Day ride and now I dont know what to do!!!!! HELP!!!
I have an 07 Street Bob
Old 09-01-2009, 09:17 PM
anubisss's Avatar
anubisss
anubisss is offline
Check your fuses.
Quick Reply: Panacea LED Light Install (no 4 ways)
