Eagle Lights LED Projection Headlight for Harley Davidson 2015 or Newer Road Glide
Check out our Road Glide kit installed! Ready to light up the night just in time for the season! You can find it here.
- EAGLE LIGHTS QUALITY - The Eagle Lights 9500 series headlight uses actual polycarbonate plastic for the lens construction for extra durability and heat treated die-cast aluminum for the body. Powered by high output LEDs, it is the best and the brightest LED headlight available to you. It is an all in one kit, with everything you need for your 2015 or newer Road Glide.
- LOTS OF POWER, LOTS OF LIGHT - At over 4000LM, there is nowhere you can't go. With a wide angle of projection and a color temperature just north of 6000K, the road will be bright, easily visible and safe.
- EAGLE LIGHTS LIFETIME WARRANTY - The light may last just as long as your bike! But should something go wrong, you are covered by a full LIFETIME warranty. No hassle returns and no hassle warranty replacement.
- READY TO ROCK - DOT approved, high lumen output, easy installation all backed by a lifetime warranty. Eagle Lights, the original, the best and the brightest. What are you waiting for?
- ALL THE PARTS YOU NEED - Have a 2015+ Road Glide model? This is the kit you need. It comes with the headlight and all the needed parts for the headlight conversion. Instructions included. Harnesses are also included to make the turn signals 100% plug and play with no splicing or cutting!
- LED TURN SIGNALS - The optional LED turn signals enhance your visibility to oncoming drivers. They can also be used as a replacement for the OEM turn signals. Connecting them is easy. With the included connectors, crimp the two turn signal leads to each of your turn signal wires in your headlight bucket
- LED power: high beam 65W / low beam 40W / position light: 10W
- Lumens: 4000LM/6500LM
- Light type: low beam / high beam / DRL White / Turn Signal Amber
__________________
EAGLE LIGHTS - SEE AND BE SEEN
120 EAST AVE
SUITE 2E
NORWALK CT 06851
WWW.EAGLELIGHTS.COM
SUPPORT@EAGLELIGHTS.COM
1-800-921-3162
Use HDFORUMS for 15% off your entire order!
120 EAST AVE
SUITE 2E
NORWALK CT 06851
WWW.EAGLELIGHTS.COM
1-800-921-3162
EasternPC_Forum
Vendor For Sale Classifieds
14
09-21-2016 06:41 PM
