OEM AGM Battery or OTHER
Old 01-01-2022, 03:19 PM
DynaLR105's Avatar
DynaLR105
DynaLR105 is offline
6th Gear
Default OEM AGM Battery or OTHER
Hi,
I am new to the forum. HNY ALL.
I have the original AGM HD battery for last 5-7 years. I typically use trickle charger when not operating etc. Time to buy a new one.
What is the general recommendation just get the OEM AGM version again or are there better and CHEAPER options available? AGM is around $200 tax inclusive here in CA.
Appreciate some recommendations ...
Old 01-01-2022, 07:11 PM
CoolBreeze3646's Avatar
CoolBreeze3646
CoolBreeze3646 is offline
Received 22,302 Likes on 7,702 Posts
Originally Posted by DynaLR105
Hi,
Search function will help you find all things battery related. Here you go, plenty good of information. Enjoy!
https://www.hdforums.com/forum/gener...endations.html
https://www.hdforums.com/forum/touri...w-battery.html
https://www.hdforums.com/forum/dyna-...a-battery.html
https://www.hdforums.com/forum/2018-...is-needed.html
https://www.hdforums.com/forum/touri...placement.html
Many options to choose from. Your Welcome
Old 01-01-2022, 11:45 PM
DynaLR105's Avatar
DynaLR105
6th Gear
Thanks
Old 01-02-2022, 06:46 AM
bustert's Avatar
bustert
bustert is offline
seems the hd is better all around but the cost. i bought the mother of the hd which is deka but it lasted a year less so that suggests that hd holds their feet to the fire on workmanship.
Old 01-16-2022, 03:04 PM
koolbreez's Avatar
koolbreez
koolbreez is offline
we have a Batteries Plus store here and that is what I use ,very good warranty
Old 01-23-2022, 10:41 AM
notmyj's Avatar
notmyj
notmyj is offline
I went with the Batteries Plus Lithium in the fall when when my AGM had a mechanical failure (broken contact in the case. Would go from full voltage to 0 volts when you tap on it). Finished the season on it, put it in the garage and unhooked it. The lithium batteries don't need to be tended for over winter storage. They loose less than 1% a month in storage, unlike a lead acid battery. If you don't have a reason to keep your battery hooked up, and have a lithium, just disconnect it and walk away.
The battery I got from them was $100 more than the AGM alternative, but went from a 1yr free replacement to a 3yr free replacement warranty. Easily worth it to me.
Sitting for a couple weeks, during the riding season, it fired up like normal with no issues. I don't mess around with chargers, tenders etc. Hook it up, ride it. End if the season, disconnect it, done.
Bdhouse61 (03-19-2022)
Drtumolo
2014-2023 Touring Models
12-22-2021 10:09 AM
Road Star
12-06-2015 02:31 AM
GMRO
04-05-2013 07:35 AM
inswva
01-28-2013 05:10 PM
hawnstar
08-09-2007 10:45 PM
Quick Reply: OEM AGM Battery or OTHER
