Electrical Help Wide Glide
Old 06-23-2021 | 07:38 AM
notyoman's Avatar
notyoman
Default Electrical Help Wide Glide
I have an 08 Dyna Wide Glide 105yr anniv edition. Can someone please tell me where i can get a keyed power source ???????????
Thanks,
Notyo
Old 06-23-2021 | 01:37 PM
Zanthamos's Avatar
Zanthamos
Go to https://serviceinfo.harley-davidson.com/sip/ select your language and locale, then Customer VIN or instruction sheet lookup, enter your VIN, then select vehicle documents, select the wiring diagram and go from there.
Look for the Accessory circuit.
Old 06-30-2021 | 07:55 AM
notyoman's Avatar
notyoman
Thumbs up Zanthamos
Thank you so much for that link there's a wealth of information there. It is ;people like you that make up for all the douche bags lol. THANKS AGAIN !!!!
Old 06-30-2021 | 08:07 AM
cbrenthus's Avatar
cbrenthus
What are you trying to install? I would probably use the parking light is the source, tap into it and use that as a signal for a relay to not rob power from the parking lights.
Old 06-30-2021 | 02:19 PM
notyoman's Avatar
notyoman
I'm running sequential turn signals they need constant power they don;t draw much at all, I was thinking of taping into the tail light run wire but don't know if its the blue/white wire or the blue wire? right now I'm getting power from a grey 3 wire plug in the diagnostics fuse panel. Getting information on these bikes is like pulling teeth !!!!
Old 06-30-2021 | 11:27 PM
Zanthamos's Avatar
Zanthamos
Tail lights are almost always the blue wire.
notyoman
06-28-2021 07:39 PM
frenchy333
Dyna Glide Pictures
06-04-2014 01:07 PM
coon555
09-15-2012 09:21 PM
zird00
06-03-2010 02:38 PM
tomtwix
09-30-2007 02:36 PM
Quick Reply: Electrical Help Wide Glide
