I have a 2017 Softail Slim and I want to tap into this orange wire with the white stripe and black ground - it is located just under the front of the tank and is switched power for the international position light, as I understand it.
I tested it and it has power in the aux or run position which is what I want - I have my led aux lights ready to connect but here is the issue.
I don't really want to cut it off or use posi-taps except as a last resort. I went to my local dealer looking for any aux harness or anything I could maybe cut off and just use the male plug end with a couple wires, but no dice.
Here are the pix - any ideas where I can get a plug with two wires to fit this? I even tried the smallest quick disconnect connectors and cut them in half down the middle but they are still too big.
Well please disregard - after looking and looking I found nothing so I used a couple t-tap spade connectors. Not much room to get them in, I thought I had some posi-taps which I think are better. But lights are on and no smoke or fire so far
