96 Fatboy right turn signal.
Just happened today,
stock 1996 FLSTF Fatboy. Nothing trick on it.
Has anybody have this problem?
What did you find and how did you fix it?
I checked the forums and I’m good at electricals, that is going to change soon.
Next stop is to the local shop when I can get off work to get it fixed. Using right turn hand signal until then.
- Right front turn signal stay on steady but does not blink.
- Indicator light stays steady, does not blink.
- Right rear light does not light up, even as rear running ligh.
- changed rear bulb, 1156, still same problems.
Here are schematics I found online. Does the rear turn signal have a good ground? I would unplug connectors and clean them and check continuity from one end to the other. If you disconnect the TSM you could hook a test light to battery positive and touch the turn signal wire going to the back and see if it lights.
