2015 Freewheel Back Light Issue
I have a 2015 freewheeler and the red warning light on the speedometer comes on and off. After reading some forums I checked the lights and found the left rear brake light is on all the time. It will flash if you turn on the turn signal. The right rear running light is on but the brake light will not come on when applying the brakes and does not flash when turning the turn signal on. The front lights work as supposed to. Before I go digging into lights and modules etc any ideas? Thank you so much.
Gbright (07-29-2019)
