LED tail light problem
01 fxdl I just installed an LED tail light and I connect ground, then running light and it's fine but when I connect brake wire the light dims down and when I hit the brake it only brightens up to what the regular running light is. If I disconnect running wire and connect brake on blue connection it's bright as hell so I know the it's supposed to work right. I'm stumped. Please help!! Thanks in advance
there are a couple of ways these are made.
on the simple style, there are two separate circuits, one for the running light and uses either a lower lumen led or a dropping resistor. on the brake side, the leds are high output.
now they have some with a chip that controls the functions. you have a single circuit and when the chip is only receiving the running input, applies a set level of current. when the brake input is seen by the chip, it supplies high output current to make the leds bright but could take away from the running. it is really hard to say. it could be a source issue, bad controller if it has one. what brand??
Ndotson19
09-08-2018 11:19 PM
wc00000001
05-27-2018 10:54 AM
